Windows 11
The pattern editor appears in the block texture editor section even without a layer. And when you try to create something without a layer, nothing ends up being applied, which is a bit confusing. (Idk if this is a bug, if isn’t, sorry!)
- Video: https://youtu.be/KPkspsqoy-o
- Enter on one map on build mode ( Login ).
- Go to the block texture selector and go to the block texture editor.
- Edit the pattern without creating a layer.
- Save it and put a block somewhere.
