perd3u
This post is dedicated to suggest new features that can be implemented to the Blokoto Terminal
Formatting:
Title that in few words say what is the new feature
description in of what it does
reason to be implemented
example applying the feature
command_name [input_name type] [example int] [example2 string] [example3 args]
// optional: output of the command
perd3u
Server Status
Show witch server are the player playing + other details
help to report server issues
A bug happens after 14 hours of constant online stability with the server, the feature would show the time, allowing replicating the event easier
Server
ServerID xxxxxxxxxxx
Adress Brazil, São Paulo
Ping 132
Alive 7:21:45 (the server)
Connected 3:43:37 (the player with the server)
perd3u
3
Mark (edit mode only)
Mark anything using a filter to quickly found what you want arround the map
In complex maps that will be build in the future, seartch tools will be essential to track and debug complex mechanics
If after a update, the creator decides to update a model with a specific texture, or change the function of a tool that are duplcated
Mark [item_type string] [filter args]
Examples:
Mark Visuals.Text, TextColor = '#ff00ff', Size = 12
Mark Spawning.Checkpoint, 17 < Cordenates.X < 32 , 90 <= Rotation.X <= 180
Mark Transportation.Portal
