Computer Specs:
Windows 11, Intel Core i5-1135G7, Intel Iris Xe Graphics, 8 GB RAM
Game Version:
Blokoto Pre5.2
Issue 1: Avatar Stuck in T-Pose When Testing in Avatar Edit Mode
Description:
When entering Avatar Edit Mode and pressing P to test the avatar in play mode, the character gets stuck in mid-air in a T-pose, without any animations. In this state, the avatar cannot walk, run, or jump β it is completely frozen. However, pressing P again returns you to Avatar Edit Mode normally.
Steps to Reproduce:
Enter Avatar Edit Mode.
Press P to enter play mode and test the avatar.
Result: The avatar appears stuck in a T-pose, floating in the air with no animations or movement possible.
Expected: The avatar should animate and respond to player controls like walking, running, or jumping.
Issue 2: Left Leg Block Canβt Be Edited on Top/Bottom Faces
Description:
While editing the avatar model, the left leg block cannot be modified on the top and bottom faces β itβs not possible to select or manipulate vertices, edges, or faces on those sides. In contrast, the right leg block works correctly and allows full editing on all sides.
Steps to Reproduce:
Select the left leg block.
Try to select or modify the top or bottom face (including vertices or edges).
Result: Interaction on those faces is not possible.
Expected: The left leg should behave like the right leg, allowing full editing on all sides.
Screenshot/Video:
