Spotlight is completely broken
The spotlight got totally useless for some reason, because it is not working the light radius configuration, so it won’t let the light working even if you put the highest values available for that.
The color selection is also broken, when you select any sort of color, it doesn’t appears as it was supposed to be.
And finally, the spotlight cannot be deleted by itself, you can see that i’ve clicked on the delete button, but it still keeps existing on the map:
