Selection outline bugs
Model Selection Not Following When Changing Size
When you have a model that is currently on size 2 for example, and then you switch it to a bigger one, the selection does not follows your change at the same time, resulting on this visual bug:
Model Selection Persists During Play Mode
The model selection still maintain the outline even when you’re in play mode:
