Selected tools are misinteracting with the game while rotating a light prop
While you rotate such a light prop like this, if you selected the paint or delete tool, when turning the prop, the game scenery behind it is completely affected, depending on which tool you have switched before the rotation, but both of them can clearly mess up your map in a matter of seconds:
It only happened to light and point light props until this moment, since i have already tested with another props previously to attest what is bugged.
