On avatar editor, let’s say I build a wall of blocks on layer 2, then I place a block behind the wall on layer 3, if I try to extend it past the wall, it doesn’t work, the only way to get the block through the wall on layer 3 is if I manually click on the block behind the wall, and then the block will get through the wall.
