Map grid preventing player movement
I entered one of my maps to build, and accidentally discovered a new bug.
Basically, whenever the grid position in the top right window of the interface is changed, right after the change, I become unable to move. The only way I’ve found to be able to move again in the game is by disabling the grid.
I know what happened there:
You’ve chosen and changed the grid position, and after it, the game locked your movement because of the grid position confirmation still there.
In other words, you need to press the Enter key to disable and confirm the position from the grid, and its confirmation can be seen when the blue outline disappears from the numeric display exterior, and finally you are able to move around again.
Not confirmed grid position
Confirmed grid position
I don’t know if this is such a kind of bug to be fixed, but Inknight knows if this is a supposed feature meant to be into game or not, but i can say for real, thats a annoying thing :joy:
Interesting, I’ll try it out
Thanks for reporting!
