I tested the installer in its first version, but at first a window appeared with the title “Error” and the content “O launcher está instalado. Acesse https://www.blokoto.com para jogar!”. The files in the “~/.blokoto” directory were downloaded normally, but the launcher did not open the game at all.
After that, I decided to clean the installation by deleting the files and directories:
- ~/.blokoto
- ~/.local/share/applications/(.blokoto desktop file)
Since I do not know which directories or files the installer modifies, I suggested that it is in these two, so I cleaned them.
But it turns out that now, when running the installer, it only downloads the file “blokoto_launcher.x86_x64” to the “~/.blokoto/launcher/” directory. All other files are not downloaded to their respective directories, which makes them impossible to run, even when trying to open the launcher.
Godot Engine v4.3.stable.mono.custom_build.6d98b8492 (2024-08-16 14:40:06 UTC) - https://godotengine.org
Inconsistent value (1) for DRI_PRIME. Should be < 1 (GPU devices count). Using: 0
OpenGL API 4.6 (Core Profile) Mesa 24.2.6-arch1.1 - Compatibility - Using Device: AMD - AMD Radeon Graphics (radeonsi, renoir, LLVM 18.1.8, DRM 3.59, 6.11.6
-zen1-1-zen)
Downloading [100%] # Here it appears from 0% to 100% normally
Online game version: 0.1.0
Online launcher version: 0.1.1
Executing /home/mb/.blokoto/launcher/blokoto_launcher.x86_64
Godot Engine v4.3.stable.mono.custom_build.77dcf97d8 (2024-08-14 23:00:16 UTC) - https://godotengine.org
-zen1-1-zen)
Bem-vindo
Creating /home/mb/.blokoto
Creating /home/mb/.blokoto/temp
Creating /home/mb/.blokoto/game
Creating /home/mb/.blokoto/launcher
(zenity:169328): Gtk-WARNING **: 19:15:12.939: Unknown key gtk-modules in /home/mb/.config/gtk-4.0/settings.ini
(zenity:169328): Adwaita-WARNING **: 19:15:12.994: Using GtkSettings:gtk-application-prefer-dark-theme with libadwaita is unsupported. Please use AdwStyleMa
nager:color-scheme instead.
Error message when installing:
Directory “~/.blokoto”:
├── game
├── launcher
│ └── blokoto_launcher.x86_64
├── meta-info.json
└── temp
