Disagreement between client and server model collision when changing scale
Title
Going through the model
Operating System
Windows
Game Version
1.2
Where does it happen?
Editing
Description
When you place an item on your map and then resize it, you’ll encounter a collision bug where you’ll either pass through the item if it’s filled with blocks or enter it if it’s hollow inside.
Steps to Reproduce
  1. Enter your game in edit mode.
  2. Place a model from your inventory or use one already existing on the map.
  3. Use the object’s scaling tool.
  4. Put the item in test mode and try interacting with it.
Explanation: This is caused by a disagreement between the client and the server, where the model has different collisions on both environments.
