Burning and going through model blocks by using patterns
If you build a model and choose a block with a pattern with burning, then it does no damage while playing and you can go through the block. Even if you set the inventory to burning again, it always goes back
Collisions got changed in the last update and some regeneration bugs are happening. Does the block stays without collision even after restarting the game?
it all finally works now! thanks
