Blocks color, different color on the map
I noticed that when we make a block very dark, it will still be lighter on the map than in the inventory. Would you like to fix this in the future to make the blocks more real and reliable? You probably can’t see any shadows on the black block. I don’t know if it would be such a big problem, you could set the block to a brighter one.
It’s probably the lighting. But you can create custom blocks of whatever color you want.
I know, but when the block is very dark, the color is lighter on the map. That’s the thing.
Just a basic light impact on the block surface, maybe it can be a little dissonant from the blocks inventory creator until it finally reaches the game scenery, it’s something we cannot fully discard, however i think it is only the skybox effect through the material.
