Blokoto version v1.2.1, Windows 10, NVIDIA RTX 2060
(Both play and editor mode) Even in the lowest settings possible, I still face absurdly high GPU power usage (temperature 75 °C), yet hardly any actual GPU usage. Most prominent while in the menu. VSync (60 fps) or playing in windowed mode does not provide any help.
(This does not happen in KoGaMa, for example)
Probably it will be fixed when the newest updates related to optimization finally arrive to the game. I suffer from the same issue too, it’s something really awful when you heat up your PC at certain point that you are constantly afraid of getting an error screen on it, and that’s the actual reason why i avoid to play it as long as possible, at least for long periods of time like half a hour or more.
This bug has a workaround: toggle the Vsync on settings on and off. It will refresh it and start limiting the FPS to your screen maximum FPS, reducing the GPU usage by a lot.
