Skybox customization
Here are a few suggestions i have, regarding the recently posted sneak peak.
  • Quantity: Option to add multiple astros (example: sun and moon, two suns, two moons etc..)
  • Position: Being able to change their latitude and longitude (position the astro occupates in the skybox)
  • Size and luminosity: How large the astro is and the amount of light it gives off, if luminosity is negative then it will make the game darker while it’s visible in the sky.
  • Movement and time: Decides whether the astro is static or moving and how long it takes to make a full cycle around the world. This would allow for players to make a working day/night cycle, as the astro would not give off light while it’s not visible in the sky.
  • Other: Stars, auroras, constelations, galaxies or other celestial bodies could also be options for sky customization. They would have same settings as the standard astro.
Will be taken into consideration for future updates! Thank you for your feedback.
