Attempting to upload a recently saved model from my inventory into a project results in the model not being placed and two small texts: ‘‘An error has occured in the server’’, ‘‘Model could not be loaded’’.
If i try to upload a model that i saved months ago it works just fine.
Can you record a video showing it actually happening?
Sorry i had issues when trying to upload the recording, but i managed to screenshot the error messages:
The error happaned when i tried to import my recently created cactus model, other (older) models work normally, like this arcade machine:
Probably it has something to do with the current textures issue. Does this model actually features textures made recently? If it does, i’m sure that the issues are interconnected with each other indeed.
It does, maybe you’re right.
I’ve also noticed other bugs related to textures and models.
If you create a texture, edit it and rejoin it will revert to its original appearance, which forces you to create a new texture if you want something different.
The other bug is related to model colision, if you disable colision on a model and rejoin colision will be enabled back (i discovered when trying to disable colision on grass and flowers so players could walk uninterrupted).
Yeah, i already noticed this problem from texture, it really has relation with those issues we have been experiencing with textures until then. Hopefully, all of those annoying behaviors will be fully fixed until the release of 1.3.0.
Regarding the collision bug, i remember to see that it was already reported on another topic, so we must only wait until the launch of the next version to see if it will be fixed as well.
